Does any-one know this - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2004, 03:04 PM
Auto-Part's Avatar
I bought a 94 Mazda MX-6 auto. with 140,000km I wanted to change the trany fluid. I get different answers some say no need to replace the trany filter and others say you should. The owner manual says "inspect" fluid levels at 30k km intervals no mention of replacing the fluid . So what do I do ???
Old 03-01-2004, 03:52 PM
302 Z28's Avatar
Why on earth would you NOT replace the filter?
Vince
Old 03-01-2004, 04:32 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Unless you are positive about the history of the transmission, I would say the filter change could be long overdue, and since they don't cost all that much it certainly cannot hurt to change it.
Old 03-01-2004, 05:22 PM
adtkart@aol.com
If the trans is working properly, and the fluids is red, change it. That is preventive maintenance. The filters are usually made of either a metal screen or some fiber substance. Many people think that the metal screens don't need replacement. The fact is that they actually will build up a coating, similar to the coating on the rest of the inside of the trans. If you remove the pan and run your fingers across the bottom of the pan, you will get some silver/black stuff on them. That same stuff is inside the filter. They should be replaced when the fluid is changed.
Old 03-02-2004, 05:49 AM
airworld2's Avatar
mazda mx 6
the reason why no filter change is mentioned. is on this trans (CD4E)
the filter is inside the tranny case and unless you remove trans and dis mantle it you cant remove it.
airworld2
Old 03-02-2004, 06:45 PM
adtkart@aol.com
Airworld....thanks for the info. I have never been inside that one.
Old 03-02-2004, 09:57 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Re: mazda mx 6
Bad part is, that's becoming quite common.
