Does anybody know the 81' Chevy half ton - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2003, 05:33 PM
Post Does anybody know the 81' Chevy half ton
I am needing some info about some things on an 81' Chevy half ton.....
Is anybody knowledgable????
-Billybob
Old 03-30-2003, 06:05 PM
Post
I have an 82 Silverado C10, pretty much the same as the 81. It used to have the 305, however, I just dropped in a 350. What is it you need? Maybe I can help...Tom.
Old 03-30-2003, 06:16 PM
BOBCRMAN@aol.com's Avatar
Post
I've had three of em, the electronic controlled spark advance dies on them, replace the distrib with an early vac advance unit and cure the hard start, rough idle ,no power blues. Had to replace a lot of idler arms also.
Old 03-30-2003, 06:56 PM
Post
What are your questions?
Old 03-30-2003, 07:54 PM
Post
Well, I access to two of them for free if I want to go and pick them up. I was wanting to know the width of the rear end from hub to hub. Also, would the master cyclinder work with with my 81' Camaro subframe that I have grafted under my 51' GMC pickup.
-Billybob
Old 03-31-2003, 03:27 AM
Post
I don't know what the rear width is but I can tell you the master is wrong for your 51's combination, use an early eighties Camaro master and combination valve.
Old 03-31-2003, 03:57 AM
EBlack36's Avatar
Rebuilt Excitment
Post
The rear on the late model pickup in more than likely way to wide. Try one out of a Nova or Camero.
Old 04-01-2003, 12:19 PM
Post
WMS width should be about 65"
