-   -   Does anybody know who/which shop may have built this 700R4 ? (http://www.hotrodders.com/forum/does-anybody-know-who-shop-may-have-built-700r4-220341.html)
'49 Ford Coupe 06-08-2012 02:54 PM
4 Attachment(s)
Just bagged a 700R4 with MD8 case and 30 spline. I read somewhere that a tailshaft with two horizontal bolt holes in it comes from a GM Diesel truck.
Thanks, Guys..
'49 Ford Coupe 06-08-2012 02:56 PM
700R4 builder..
The stamped numbers were obviously done after painting. Has anyone ever seen these codes ?
Prof. T. Soggmeyer 06-08-2012 05:32 PM
Your "codes" are stamped on the passenger side of the trans at the rear right above the pan.
Brad...
cobalt327 06-08-2012 07:37 PM
Possibly from a F-body: http://www.chevelles.com/forums/showthread.php?t=289470 , although I know there are three-boss torque arm mount trannys, too
joshp83 06-09-2012 02:10 PM
the f body has 3 holes for the torque arm the 2 hole is from a van they used a weight that bolted to it
'49 Ford Coupe 06-09-2012 04:26 PM
Brad...
Thanks, Brad... I know about the "regular" codes on the pan flange, but these were added later in the top of the case just in front of the tailshaft mount. Just thought somebody may have run across a rebuilder who may be putting their own codes in the case to show what's in there...The rebuilder MAY be in Houston, but that's just a guess...
Any Houston guys on here ???
Thanks.
