Does anybody know who/which shop may have built this 700R4 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2012, 03:54 PM
'49 Ford Coupe's Avatar
1949 Ford Coupe RESURRECTION
Just bagged a 700R4 with MD8 case and 30 spline. I read somewhere that a tailshaft with two horizontal bolt holes in it comes from a GM Diesel truck.
Thanks, Guys..
ID:	65937   Click image for larger version
ID:	65938   Click image for larger version
ID:	65939   Click image for larger version
Old 06-08-2012, 03:56 PM
700R4 builder..
The stamped numbers were obviously done after painting. Has anyone ever seen these codes ?
Old 06-08-2012, 06:32 PM
Prof. T. Soggmeyer's Avatar
Plan B
Your "codes" are stamped on the passenger side of the trans at the rear right above the pan.
Brad...
Old 06-08-2012, 08:37 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Possibly from a F-body: http://www.chevelles.com/forums/showthread.php?t=289470 , although I know there are three-boss torque arm mount trannys, too
Old 06-09-2012, 03:10 PM
pricesgarages's Avatar
the f body has 3 holes for the torque arm the 2 hole is from a van they used a weight that bolted to it
Old 06-09-2012, 05:26 PM
Brad...
Thanks, Brad... I know about the "regular" codes on the pan flange, but these were added later in the top of the case just in front of the tailshaft mount. Just thought somebody may have run across a rebuilder who may be putting their own codes in the case to show what's in there...The rebuilder MAY be in Houston, but that's just a guess...
Any Houston guys on here ???
Thanks.
South African rod shop makes out they built my sedan delivery. cboy Hotrodders' Lounge 22 11-01-2011 04:40 AM
700r4 built pressure blew line, fixed now no d/od AmcXcar69 Transmission - Rearend 3 04-19-2009 05:58 AM
built 700R4 or typical th350 my87Z Transmission - Rearend 7 03-31-2009 07:28 PM
Who's built a waist oil burning stove for there shop? Cliff Elikofer Garage - Tools 4 03-09-2008 09:34 PM
Ive been gone for a while, got our shop built. Rubberman2003 Hotrodders' Lounge 12 09-07-2004 10:40 PM
