Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - does anybody now anything about a 4L60E?
Old 07-09-2006, 06:03 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
your factory onboard computer receives signals from the lt-1 motor. A TPS , RPM feed, temp of engine, air temp, many data feeds to the computer.
you need these data inputs to operate the 4l60e trany with the factory control computer.
I have not performed these types of conversions , I cannot provide guidance there.
A converter change will not help the 4l60e strength..... the 427 engine if it is strong will break many internal parts of the 4l60e.
for your viewing pleasure... an input shaft of a 4l60 that was behind a powerful small block chev engine.
Originally Posted by 94impalass
thank you crosley i am glad you explained it to me so what you are really saying is that i need the tci transmission controller? so what would i do with the computer that is already in the car i should just take it out. oh also if i get a bigger torque converter will that make my transmission last alot longer?
