Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Does anyone have any suggestions on pistons for a Chevy 350?
Old 01-07-2010, 10:06 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by DEMONSPEED
I'm going to go ahead and say thank you to all of you that have helped so far before I forget. http://www.summitracing.com/parts/STL-H345NP20/ So given the info I have gathered from you all how do these sound?
Looks OK to me. I don't know if they're available for less somewhere else, but the piston itself looks good.
The spec: "Compression Distance (in) 1.560 in." is an important one- this means that the quench distance will automatically be 0.020" 'better' ( higher in the bore at TDC) than if you used rebuilder-type cast pistons that often have a 1.540" compression height.
Keep this spec in mind so you can tell the machine shop, should you have the block decked. It'll make a difference as to the amount of material that needs to be removed to get the quench right.
