Does anyone have an interchange? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2006, 10:07 AM
WoodsEdge's Avatar
Can someone tell me what will interchange with a 1995 Astro Van differential?
Thanks, Jack
Old 09-12-2006, 10:25 AM
astroracer's Avatar
A 1995 Safari differential...
The Astrofaris use a very long diff. It is 65" over the brake drums (my full size truck is only 62")... PLUS the pinion is offset to the passenger side almost three inches to match up to the engine location which is offset also.
You don't have any options here. The diff HAS to come from an Astro or Safari. Most any year will probably work but watch for composite spring mounts and different brake packages.
Mark
Old 09-13-2006, 10:24 AM
WoodsEdge's Avatar
Yep, I was afraid that was the case. How about the ring and pinion, any thing else fit?? I'm trying to get out cheap.
Thanks again, Jack
Old 09-13-2006, 10:32 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you go on www.car-part.com someone may have one for reasonable..that is the national used parts interchange..
Sam
Mopar Transmission interchange Albo Transmission - Rearend 1 06-22-2006 01:18 PM
Hollander Interchange? Longboard Hotrodding Basics 3 04-03-2006 08:15 AM
access to Hollander auto interchange book tm454 Body - Exterior 3 03-18-2004 06:37 PM
What fenders interchange with my 47 Chev 47 Chevy man Body - Exterior 1 01-30-2004 07:23 PM
Steering wheel interchange??????????? Darkman270 Suspension - Brakes - Steering 0 11-06-2003 08:59 AM
