Does anyone need a big compressor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2005, 08:35 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
I am just curious to see if anyone out there, namely another shop, needs a good, large air compressor. I ended up with one that is just too large for my shop. I will eventually grow into it, but not for a while. If anyone here needs one, please contact me at the link in my profile. Thanks
Old 08-01-2005, 12:01 PM
TOO MUCH Compressor!!! Now there is a new angle!
J K - I would just count my blessings and hang on to the thing!
Old 08-01-2005, 06:40 PM
Last journal entry: frame build
WOW a 500+ cfm compressor? No such thing as too much compressor only too much cost to run it. Wouldn't it be wonderful to be able to sandblast with a comp that rarely runs at much more than idle?
Old 08-01-2005, 08:02 PM
topfuel's Avatar
Here's a quick rundown for everyone. It has a 25hp 460v 3ph motor. It is a 4 cyl., 2 stage pump that puts out 82 cfm @ 120 psi. Max pressure is 200 psi. The tank is 8 ft. long and the top of the compressor head is over 5 ft. tall. This thing is a monster. The compressor at the local chevy dealer is smaller!
Old 08-02-2005, 08:18 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
OK. you win.
This is the FIRST overkill I have seen in here.
Old 08-02-2005, 04:30 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
Hey atleast you wont run out of air...ever lol
Old 08-04-2005, 04:39 PM
Dang, I have no room in my little garage now, I can't imagine that thing. Is this like the locker room in highschool and you are trying to make everyone walk out of the shower in shame.
Old 08-04-2005, 09:08 PM
I worked at a shop that had one 65 hp and one 75 hp screw copressors for one blast booth and one paint booth. There were a few other small items that ran on air and they had 4 storage tanks 4 ft diameter by 15 ft tall.
Jeff
Old 08-05-2005, 05:50 PM
topfuel's Avatar
kenseth, that wasn't my intention at all.
Just for laughs, I'll post a pic or 2 of it.
Old 08-06-2005, 02:33 PM
Last journal entry: Transmission Table
I gotta see this.
Old 08-07-2005, 07:43 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
hey i'd take it. It wouldn't have to run often or for very long.
Old 08-08-2005, 08:57 PM
montea's Avatar
tryn to learn
Old 08-09-2005, 04:27 PM
topfuel's Avatar
They're coming montea, they're coming. I'll try and get them taken and posted asap I promise.
Old 08-09-2005, 09:00 PM
It depends on what you consider too big. I work at a steel mill and the compressors that blow air into the blast furnaces puts out 198,000cfm. I think that would be too big. And when looking at the compressor it amazing how small it is. It is only about 4 feet long and about 2 feet in diameter. But it is driven by a steam turban and runs at about 200,000rpm. It has hundreds of little vanes inside to make the air. It only runs at max of 55psi but they get upset at that pressure and like to run 35psi. If it gets much over 40 the power house is calling the furnace telling them to back it down. We also have the ones over at coal injection that run a high pressure and a 9000 hp 3 phase 13,800 volt motor. Sure make a lot of heat. OK I have bored you enough.
Old 08-10-2005, 02:43 PM
454, Not boring at all, in fact that is quite interesting
choosing a compressor oldred Garage - Tools 12 03-14-2012 09:40 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Big cars Wmarden Hotrodders' Lounge 16 09-12-2004 08:05 AM
engine too big? deuce_454 Engine 11 04-04-2003 02:46 AM
big tires? cannedheat Body - Exterior 6 10-16-2002 12:35 AM
