Does anyone think 3M's Trizact is WAY overpriced? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 05:15 PM
I have heard all kinds of talk about trizact and finally tried a pad of 1500 grit and it seemed to work well (6" Dynabrade fine sanding DA). It didn't leave swirls too deep.
But at $3 a sheet!! Wow. Anyone think this stuff's a little too pricey?
Anything out there that works as well for les$?
Old 07-11-2011, 11:32 PM
put up or shut up
I tried indasa style ones and I can't even tell if it's working. Trizac lasts a long time and is worth it if that's your thing. Plenty of shops where I worked used it cause it's fast and it's cost effective, otherwise they wouldn't use them. I like wetsanding by hand personally.
Old 07-11-2011, 11:52 PM
I have to admit... it works good.
I did some hand sanding tonight and I could see lots of linear scratches after buffing.
Seems like the Trizact does do a good job. There are still swirls but they're not very deep.
Old 07-13-2011, 12:50 AM
Its expensive but works great. I had similar problems with scratches while hand sanding even when wetting car and sandpaper with hose.
Overpriced? SJ's Mustang Hotrodders' Lounge 17 11-18-2010 07:16 PM
overpriced stores old fords Off-Topic 25 01-17-2010 12:32 PM
