does a carb spacer make a difference? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2011, 09:02 PM
i have one and i modded it to the size of my intake manifold. how much more flow would that create? i also found a gasket that matched the carb spacer, so its all lined up and ready to go, but does it really make a difference?
Old 08-03-2011, 10:08 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
carb spacer
There are a lot of factors inolved. But as a general it can increse the signal to the carb,Seems on my 409 top end power was improved.Try it , can't hurt much.
Old 08-04-2011, 09:23 AM
FASTFORD's Avatar
generally, a 4 hole spacer will help low end power and an open spacer will aid top end.
Old 08-04-2011, 10:47 AM
id show you a pic of it but i already sent it to my mechanic. i just had surgery and will have another in a month so i cant work.
basically i just cut out the "extra" metal and gasket to fit the four barrels on my carb so it would flow more freely.
Old 08-05-2011, 11:00 AM
techinspector1's Avatar
Wiki Edits: 326
Carb spacers are not a one-size-fits-all type of part. Different motors and different motor combinations like different spacers or no spacer at all. It's pretty much a try-it-and-see operation based on quarter mile time slips and how you perceive the motor to be acting at different rpm levels.
Old 08-05-2011, 08:23 PM
thanks for clearing that up
Well I did the spacer shaving because engine performance is all about flow, not just what works
Old 08-06-2011, 01:18 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I tryed a spacer on my drag car motor on the dino. and it lost power. I told the dino guy but when we put it on last year at the track we picked up et in the 1/4. He said it took some of the power out of the car and the et we were seeing was lost tire spin. So it a try it and see what works. we went out on a test day made three good runs back to back then put on the spacer and made three good runs with it on back to back and compared et,s
Will adding 1 inch to fan spacer make a difference? lazydawg Engine 8 06-14-2009 08:33 PM
Carb install, spacer or no spacer? MM in NM Engine 3 03-17-2006 06:23 PM
Does BG make a matching 4 hole spacer? commando57 Engine 1 06-13-2005 06:11 PM
Th350 going to break, how to make spacer plate holes smaller? Jason Transmission - Rearend 7 06-30-2003 10:29 PM
Need to make a air cleaner spacer Jag Daddy Engine 3 04-22-2003 09:32 AM
