does chevy fit pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2009, 04:13 PM
I have be building a 1939 pontiac 2 door sedan,I have eveything except rear fenders, will chevy fenders fit my pontiac?
Old 11-05-2009, 07:07 AM
Wiki Edits: 27
mabe ?
Most buick and olds parts from the 30's will fit pontiac's. I don't know when they changed to make chevy and pontiac blood brothers.
Old 11-05-2009, 07:41 AM
poncho62's Avatar
Wiki Edits: 5
I know with Canadian cars, a lot of Chevy/Pontiac parts interchanged over the years.....but not sure what years and models.
Old 11-07-2009, 06:04 AM
still looking for an answer
thanks for the input,that is what I have been hearing.Geuss the only way to really find out is to just order me one fiberglass rear fender for a chevy,which wouldn't be a huge loss if it didnt fit.I have looking at car shows and have not found any cars similair in our area.learning from experience I bought fenders for a 1939 pontaic four door,my luck they are not the same,diffrent wideths,lenghts and mount diff.so I have me two rear and two front and a hood which are no good to me! Thanks again!
Old 11-07-2009, 11:25 AM
ryork's Avatar
38 LaFayette
Last journal entry: Got a little help..
I have a 39 four door 8 cyl and needed a rear roll pan. I ordered one for a chevy and it was too short. I was told that the standard 6 cylinder pontiacs used the same parts as chevy, but the bigger 8s and super 6s were a little longer and wider and most chevy parts were not the same. I have no experience with the parts except for the roll pan.
Bob
Old 11-07-2009, 11:46 AM
39 pontiac
Do you have a model 6-25 or a 8-28 they are different.
The 6-25 was unique to itself per my Hollander Interchange but the
8-28 series would interchange with the corresponfing buick/olds. The chevy
listing for the 39 is also chevy specific. Note that while the show the
buick/olds fenders as fitting the 8-28 they may not be identical- different
gas fillers or light holes for example. Good luck with it Jim
Old 11-07-2009, 05:14 PM
thanks for the input guys,I have a 25 model I believe,well it says body style 39 2511 on the tag.I may be i luck,there is a guy local that has some nice chevy fenders and he is comeing over tomarrow to see if the fit,sure hope they do,I'll let you know if they do just for further nowledge!also it doesn't matter where the fuel cap is for me,that is if that would be one of the only diff.
Old 11-09-2009, 04:45 PM
alright,the chevy fender did not fit.It was to long and bolted on all diff.yet still looked very similair.
Old 11-09-2009, 06:45 PM
You might try some Canadian stuff if you can...
Some models were very different there. Not only in GM, but also in Mopar, we got the run-off from it here because our market was similarly 'compact' and needed model pruning.
You see a lot more of it in later years, where Pontiac bodies are bolted onto Chevy chassis right through the sixties for the export market.
In Australia there was also the paradoxical situation where some bodies were shared between GM and Chrysler aft of the windscreen. Willys, also, joined in this, their '34 body becoming the '35 Vauxhall 25hp body IIRC.
trying to put a chevy 350 in a 1969 pontiac le mans 54chevy22 Engine 15 09-10-2014 05:27 PM
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
81 Spindles fit a 71 Chevy Truck? CarNutCertified Suspension - Brakes - Steering 9 05-24-2008 01:40 AM
Phew my Pontiac almost got a Chevy Matoma Engine 7 05-22-2008 01:39 AM
Small Chevy car wheel to fit Chevy Truck musky2 Transmission - Rearend 4 03-16-2004 08:12 AM
