Does converter slip more with low gears? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2012, 07:13 PM
For 1/4 mile, I'm swapping my 3.0 gears for 4.11s. My converter slippage is 3%-7% with the 3.0s. Will the percent of slip change with the 4.11s? I would think it might be tighter.
Old 09-16-2012, 09:30 PM
WDCreech's Avatar
Grumpy Old Goat Herder
A lower gear (higher number) will slip less because it's easier to turn. The only way to tell what % is to run with a drive shaft/engine rpm data logger.
Bill
converter and gears chevbeatsford General Rodding Tech 10 06-22-2010 02:40 PM
2 New 700r4's Wont Shift From Low Gears? redlinecustomz09 Transmission - Rearend 4 01-06-2010 06:11 PM
low rear end gears dking Transmission - Rearend 2 07-20-2009 08:16 AM
Is A Stall Converter For Me? What Gears Should I Run? 1973ChevroletNova Transmission - Rearend 1 05-20-2003 01:57 AM
gears too low? kalel Transmission - Rearend 3 02-07-2002 03:20 PM
