Does direction of residual valve matter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2012, 08:35 PM
Vetteman61's Avatar
Last journal entry: Moving my Journal
I know why residual valves are needed and all of that but in my searching I haven't found an answer to this question.
Does it matter which way the residual valve is turned?
Thanks,
Brandon
Old 04-13-2012, 09:24 PM
milner's Avatar
yes it does, the valve is designed to flow in one direction only. they are always marked for flow.
Old 04-13-2012, 10:33 PM
Vetteman61's Avatar
OK, thanks. Good to know ahead of time.
Brandon
Residual Pressure Valve BEFORE or AFTER Prop. Valve? matt2491 Suspension - Brakes - Steering 13 10-16-2010 03:51 PM
Residual Pressure Valve? BMM Suspension - Brakes - Steering 4 11-07-2007 10:25 PM
Why Residual Valve Needed??? Mel Smith Suspension - Brakes - Steering 4 05-18-2007 08:21 PM
56 chevy and residual valve 56don Suspension - Brakes - Steering 3 05-19-2003 06:47 AM
gm residual valve oldcarguy85 Suspension - Brakes - Steering 1 02-09-2002 02:30 AM
