Does everything have a fuel return line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2010, 03:34 PM
I am putting a 1978 454 into my 1970 monte carlo. when i looked at my fuel line there was only one but the fuel pump has a place for a return line. does every car have one? the car had no motor when i got it. i have built the motor through an instruction book but it doesnt cover hooking it up and making it run. thanks
Old 10-07-2010, 03:45 PM
T-bucket23's Avatar
Wiki Edits: 26
Some do and some dont, depends on the vehicle. If the car does not have a return line to the tank then I would get a pump without the return nipple.
Chet
Old 10-07-2010, 04:40 PM
From what I understand, the fuel return line was added to allow fuel to flow continuously, even if the carb is not drawing much fuel, and that keeps the fuel cool enough to prevent vapor lock. Your car may run fine without a return line under hot conditions, but you never know.
Bruce
Old 10-07-2010, 07:11 PM
thanks that is a relief that some dont have a return line. should i get a new fuel pump or can i just block off the outlet? i need to research if a 70 monte had one or not
Old 10-07-2010, 08:29 PM
techinspector1's Avatar
Wiki Edits: 326
If you are smart enough to put the motor together, then you are certainly smart enough to add a return line to the Monte Carlo. Do not plug the return line on that pump. Either run a return line and use that pump or use another pump that has no return. Your Monte Carlo did not originally have a return line. The motor was carbureted and used a mechanical fuel pump that had pressure low enough that the pressure did not overpower the needle and seat in the carburetor bowl. I don't know what carb you're using, but the AFB, Performer and Quadrajet will not tolerate over about 5 psi fuel pressure. If your pump builds more pressure than that, the excessive pressure will blow past the needle and seat and load up the intake manifold with raw fuel. You will have a tuning nightmare on your hands.
Electric Fuel pump needs a return line ? XRedRavenX Engine 4 08-20-2008 12:29 AM
electric fuel pump return line? meev182 Engine 4 05-04-2006 01:56 PM
Fuel Return Line? airman_turtle Engine 7 09-10-2005 05:07 PM
fuel return line Q nova 1 kenobi Engine 6 03-13-2005 05:25 PM
Fuel Line Q S10Fan Engine 1 07-26-2004 05:11 AM
