Does exhuast after muffler effect performance? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-16-2013, 02:00 PM
Banned
tail pipes need to be mandrel bent or they cause backpressure no matter how much the air has cooled..
the crimp bends of jobber pipe are a flow restriction.
run your car for an hour cruise and put your hand on the tail pipe, you might just burn yourself.
  #17 (permalink)
Old 06-16-2013, 04:44 PM
carolinacustoms's Avatar
Automotive Extraordinaire
If I understand correctly you are going to run dual exhaust from the headers/manifolds to single inlet/dual exit mufflers, then run two pipes out to the bumper and connect two into one and dump behind the mufflers? Are you using cut-outs or are all the pipes gonna be open all the time? I'm not criticizing you, just wondering if it has any special purpose or just to have something different?
Kelly
  #18 (permalink)
Old 06-16-2013, 07:23 PM
Kelly
Yes you have it right, The two outter outlets all the way back and the two inner outlets connected to one dump behind the muffler.. All pipes open all the time.
I was hoping to get a unique and wholesome sound... without hurting flow. Or being to loud. And yes I want my truck to be different in every way.
  #19 (permalink)
Old 06-16-2013, 09:03 PM
Ok, like I said not trying to criticize, just wondering why
Kelly
  #20 (permalink)
Old 06-17-2013, 01:16 AM
I only had enough money to go from my headers to mufflers with 2.5" pipes dumped before the rear axle when I first built my motor. When I added 2.5" tail pipes, just a "U" shape over the axle, and dumped behind the tires, I needed to really change my tune just to feel any power. But it wasn't like before. So I cut the pipes off. I have since changed to a 3" exhaust, but haven't put the tail pipes back. I don't think I will.
The Following User Says Thank You to Super70DeadSled For This Useful Post:
0trbo4myCHEVUICK (06-17-2013)
  #21 (permalink)
Old 06-17-2013, 01:59 AM
thinwhiteduke's Avatar
Living In The Past
So are you saying that you feel like you lost power after you added the u shaped tail pipes to the system as opposed to the dump before the tail pipes ?
Duke
  #22 (permalink)
Old 06-17-2013, 02:26 AM
Was this mandrel bent pipe? You sure it just wasent as loud?
It only makes sense that the engine would perform better when immediately expelling exaust from the muffler. You would think with 3 outlets on two mufflers there would be little restriction. Maybe I should run 3'' after the mufflers...
  #23 (permalink)
Old 06-17-2013, 02:32 AM
Kelly
Would you consider this a waste of time if looking for a unique sound with performance being top priority?
  #24 (permalink)
Old 06-17-2013, 02:57 AM
Robo Moto! My wife bought me the cold air intake for fathers day, she's an awesome person! Also the motor sits in our living room for now. Easier to read bedtime stories and tuck in at night
And the answer is yes, I have slow danced with the engine. And she's a freak
  #25 (permalink)
Old 06-17-2013, 08:25 AM
Banned
ok let's get a crank & pistons in this motor. plant it in the truck. then we will finish up this 3 pipe Exhaust!
  #26 (permalink)
Old 06-17-2013, 09:32 AM
Faith - Respect - Trust
For me it would be an easy decision to make...if performance was my priority, screw the unique sound, if sound was the priority...well it can hard to get both...although to me most fast car sounds good...it's all about what you want and how much your prepared to give up.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
  #27 (permalink)
Old 06-17-2013, 10:39 AM
Yeah it sure sucks pulling the crank and pistons out of the box just to admire, lol. Wish i knew what to do with them id be driving this thing! Instead im saving up for balance/assembly cost.
  #28 (permalink)
Old 06-17-2013, 11:31 AM
ogre's Avatar
the 'Duracell Project'
your wife is definitely a keeper
The Following User Says Thank You to ogre For This Useful Post:
  #29 (permalink)
Old 06-17-2013, 09:18 PM
It really is up to you sir. I have never seen or heard a set up like you plan to build, so I say go for it and see what happens. If you don't like it, a few minutes with a saw and problem solved
Kelly
  #30 (permalink)
Old 06-18-2013, 12:16 PM
Awsome! If its never been seen or heard then its no waste of time to me! Im sure it will perform fine.
Building a performance muffler Blackdog Engine 4 06-22-2010 09:22 PM
Building a performance muffler Blackdog Engine 3 06-20-2010 05:49 PM
What Is The Best Performance Muffler ? sscanrun Engine 3 06-09-2009 08:47 PM
Quietest Performance Muffler??? budthespud Engine 7 03-11-2008 02:56 AM
quietest performance muffler spinn Engine 16 10-19-2004 12:34 PM
