does it matter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2012, 07:46 AM
does it matter
If I have a 4 relief flat top piston with a direction indicator,does it make a difference if it is on backwards.(they put the piston on the rod 180 out.)thanks
Old 02-05-2012, 08:11 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Is this motor on a stand? make it right.
The pistons are marked for a reason. Some have offset pins, the valve reliefs are cut specifically, the rods may now be backwards too as far as chamfer orientation on the crank, the pistons are designed for specific thrust forces when in operation, etc etc etc.
Old 02-05-2012, 08:23 AM
Thanks,figured as much and yes on a stand and have already pulled it back out.The last piston to install and just wasn't paying attention to rod stamp and indent orientation when the auto student put it on for me.I am sure it will be a good learning experience for him.No harm no foul.Thanks for your reply.
Does It Matter salamanca Hotrodding Basics 2 07-30-2010 12:09 PM
Which is better, or does it matter? GMW Body - Exterior 2 06-04-2007 12:42 PM
Cam for 460 EFI? EFI - Does it matter? offroadin Engine 2 06-22-2004 06:49 AM
Does it matter? Erk Engine 10 03-27-2004 05:15 PM
Size does matter Halloweenking Hotrodders' Lounge 4 05-17-2002 11:57 PM
