does it matter "sanders" - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2009, 01:29 PM
what kind of sander should be used to sand a car.
Old 08-14-2009, 01:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Depends..Da for sanding...finishing sander for clear coats..also paper makes a difference and how much you wish to spend..Sometimes guys use rotary sanders for stripping..are you confused yet?
Sam
Old 08-14-2009, 03:18 PM
I'm no pro, but I've been advised to use a Orbital/Dual Action (DA) Sander or an Inline Sander for larger flat areas. For beginners like us, it is recommended to use them only to take down heavy filler. Once it is thinned, use long boards for block sanding. Once you have experience using it, you can use it in a more versatile fashion. Also, DA sanders can warp sheet metal if you dig in too much on one spot... gotta keep it moving.
I bought DA sander from TCP for about $35 and an inline from Harbor Freight for about the same price. Like I said, they are awesome for taking down the filler, but recommend going manual style for the finishing touch.
I hope that helped you.
-Danny
The Following User Says Thank You to danny_g For This Useful Post:
brownclee (01-07-2015)
Old 08-16-2009, 11:17 PM
BMM BMM is offline
Orbital Sander. Anywhere from $40 for a piece of ****, to 300 for a well known, quality piece like a CP or Hutchins.
Old 08-17-2009, 06:50 AM
deadbodyman's Avatar
Wiki Edits: 11
I bought a used hutchins at the pawn shop ten years ago and I'm still using it $40.00 They also make a da line sander that totaly blows all the others away(for large flat areas and bondo work)Whether its used or new you'll never need another one...there the best on the planet.
The Following User Says Thank You to deadbodyman For This Useful Post:
Does air hose I.D matter? acquadigio79 Body - Exterior 18 08-05-2009 01:03 PM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 35 12-28-2006 10:11 AM
Valve Stem Angles, Do they Matter? Truth or Fiction? QuenchPiston Engine 2 12-26-2006 01:12 PM
Does interior matter? Iroc'o Hotrodders' Lounge 10 07-22-2004 09:09 PM
Man no matter how fast is a joke. RANGER_MIK Hotrodders' Lounge 1 12-06-2003 07:05 AM
