Does my car need trunk pans? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-14-2014, 05:14 AM
deadbodyman's Avatar
Wiki Edits: 11
Good point...the exhaust fumes are another issue....Don't forget,THERES A GAS TANK UNDER THAT FLOOR!!!! don't weld or make sparks until its outta there...NOT EVER...I,ve seen many ,many gas tanks rotted on the top just like that floor...
  #17 (permalink)
Old 05-19-2014, 10:56 AM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
I corrected the pics to see more detail. That floor is 85% better than anything I usually start with...
The suggestion to clean it well with a wire wheel is going to be the best place to start. Then de-grease it well and use Brian's suggestion of glassing over the holes. I would suggest that long before trying to weld any patches with a flux-core mig. There is still 90% structural integrity there and the small amount of rust will be OK for quite some time, once it is cleaned and sealed.
  #18 (permalink)
Old 05-19-2014, 11:02 AM
mmmm, beeeeer
  #19 (permalink)
Old 05-19-2014, 11:17 AM
Good job Yep, get her done!
  #20 (permalink)
Old 07-13-2014, 11:46 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Fiberglass the floor then get those side panels. Those holes on the side need to be sealed. IF you're on a really tight budget cut plywood fillers then glass them in. Boats are made that way -- it's not a "proper" repair for a car, but will work since there is no structural strength there. All the things you fiberglass on top you need to undercoat real good underneath. Any metal or wood sealed away from air (oxygen causes rust more than water -- it's the oxygen in water held close to the metal that causes water to rust metal) won't rust or rot, assuming it was dry when sealed.
  #21 (permalink)
Old 07-13-2014, 01:55 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I don't agree that you need trunk pans. The passenger compartment must be sealed off from exhaust fumes. If you were to cut the whole back of the car off, a body mount would not be necessary also. It would be like the cab of a pickup truck and they don't have trunks.
But it would probably be easier to just fix the trunk floor.
pans, trunk
weather stripping my doors and trunk, 51 chevy car Joe Lucero General Rodding Tech 2 10-13-2012 07:36 AM
Spot welding floor pans and trunk thatshimman Body - Exterior 16 11-21-2011 06:00 AM
Sooooo, I open up the trunk of a customers car today.... MARTINSR Off-Topic 29 06-03-2008 09:55 PM
Floor Pans Rag top bird Body - Exterior 0 01-08-2008 09:20 PM
oil pans vega dog Engine 2 02-04-2003 09:48 AM
