Does my el camino have too big of a camshaft?? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 10-29-2007, 08:45 PM
There you go. The answer is in your last post. If you can determine at which point the engine wouldn't idle. Even if it means putting the old dizzy back in. To get you idleing and running again. I mean during one of those changes, little changes, everything didn't come back up like when you first got the car. Make any sense ? BTW. my favorite icon: stressless
  #47 (permalink)
Old 10-29-2007, 09:40 PM
Last journal entry: epoxy paint
I am thinking of paying $9 bucks to get new springs and weights for the distributor, get a fuel regulator, retune the carb. (including adjusting floats), re-re-check TDC and the dampers timing mark. The spark plug wires have been quadrupal checked. Im also going to check for any vacuum leaks by plugging up all of the hoses.
I may even get smaller jets if the fuel regulator and float adjustments show signs of improvement in performance. A buddy of mine said that he had the same problem. First thing he said was that his carb was too big. He got a smaller carb and it works fine now.
On Saterday I painted her inside the storage unit, which is an 8x30 unit. There was ash in the air due to all of the Fires around here in Southern California. I have the first sealer coat on her and its good to see her in a fresh new coat.
  #48 (permalink)
Old 10-29-2007, 10:50 PM
Then that's when it stopped idleing and running in gear ?
El Camino = The Road
Later
  #49 (permalink)
Old 11-02-2007, 05:37 AM
Knows everything about nothing
Last journal entry: Ever forward
This may sound stupid but, is your exahust system free of obstructions?
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
adapt 94 IFS onto 66 el camino Echofive Suspension - Brakes - Steering 5 05-21-2004 10:21 AM
Finding 72 El Camino Disc Brakes sb72elcamino350 Suspension - Brakes - Steering 2 03-19-2004 06:35 AM
64 el camino brake conversion camino_man Suspension - Brakes - Steering 0 01-30-2004 06:01 PM
