Does my SBC need to go back to Machine Shop - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2012, 10:12 AM
baxternick's Avatar
I just purchased a SBC 400 over the weekend. The block was in a plastic bag. It was machined 4 years ago and was bored .30 over, honed, decked, cleaned, and all new freeze plugs/bearings. It has sat since then sealed in the corner of his garage. The owner had been oiling the cylinders, and bearings bi-monthly. The outside of the block and valley has some surface rust very lightly. All the areas that the rotating assembly go in look perfect. Do I need to take the motor to get honed again from sitting so long, or just throw it together?
Old 09-24-2012, 10:32 AM
RWENUTS's Avatar
Take it apart, clean up the bores and make sure the rings are all not stuck and aligned right.
I'd check everything since it's easy to do now. Check bearing clearances, mike the crank, make sure all the bearings are the right size.
Treat it like a new rebuild. You're never sure what you got till you tear it apart and check it out.
Old 09-24-2012, 10:59 AM
baxternick's Avatar
I purchased just a block. I ordered Eagle street strip rotating assembly for it last night. So it was bare except main caps and arp cap bolts.
Old 09-24-2012, 11:02 AM
vinniekq2's Avatar
wash the block when the parts arrive.You will have to fit the pistons anyways.
Old 09-24-2012, 02:44 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
X2 what vinnie said, and be sure to use bore brushes on all oil passages, nooks and crannies with a good detergent.
Semper Fi
Old 09-24-2012, 08:54 PM
scotch brite where its rusted and oil it asap you should hone it to fit the new pistons
Heads back from machine shop.... pics inside! sexypizzaman Engine 23 11-19-2009 09:26 AM
Help Me Out - SBC - Machine Shop Work S10 Racer Engine 7 12-31-2007 10:34 PM
Bowtie heads back from the machine shop RippinRon Engine 6 12-02-2007 07:17 PM
engine back from machine shop...what now? awoodman Engine 2 09-02-2007 08:15 AM
More machine shop advice. 400 sbc jtybt Engine 16 02-17-2006 04:30 PM
