Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Does This Really Work? Tire Balancing Beads
Old 04-04-2011, 03:50 PM
Hemi-Meadowbrook Hemi-Meadowbrook is offline
They work on the same principle of fluid harmonic dampers. However, with driving an SEMI as experience, putting them inside the tire adds wear to the tires from the inside out. They ARE NOT recommended. I've seen the evidence of lead shot and golf balls that have penetrated the rear of the cab when a tire had blown. Not fun! P-car tires are manufactured to different specs and due to their smaller size have less variables in manufacturing. Big (30" and up) tires have different harmonic issues that can be stabilized by a ring that contains fluid and lead shot. HOWEVER, they balance not only the tire, but the entire wheel hub! Extends the life of the tires on big trucks significantly! Especially when tires can be $300-600 per tire. Check this out if ya want to know how they work...
