Does SBC Timing go CW or CCW? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 02:40 PM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
I am trying to start up my motor in my newest project. It seems that it is too far advanced, I think I should turn it clockwise to retard it. I can't turn it any more as the distributor hits the firewall. My thought is moving each spark plug wire one hole either clock wise or one hole counter clock wise. My question is which way do I go?
Old 11-23-2010, 02:49 PM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
timing on a sbc goes clockwise
Old 11-23-2010, 02:51 PM
84 stroked ss
i believe to retard it you shouldgo counter clockwise with it but i may be wrong
Old 11-23-2010, 03:13 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
If moving the distributor clockwise you are retarding timing on a SBC, the rotor spins clockwise inside the dist. IMO I would pull the dist out and reset it so that you have more room to turn it.
Old 11-23-2010, 05:30 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2 i'm with you on this.
Cole
Old 11-23-2010, 09:08 PM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
So I should move the distributor clockwise 1 tooth to allow it tp move counter clockwise so it can be retarded?
Old 11-23-2010, 09:57 PM
NOlowrider's Avatar
US Navy-Retired
I believe I am correct with this.
If you want to just move the plug wire one position, then you would go one lug clockwise.. The engine does not care where the #1 wire is, as long as the rotor lines up with the #1 lug on the cap and you have it as TDC.
If you want to restab the dist to get more rotation, you would go counterclockwise with the rotor.
Looking at the dist, advancing the timing would be counterclockwise. Retarding is clockwise..
http://www.boxwrench.net/specs/chevy_sb.htm
Please, someone correct me if I am wrong.
Old 11-24-2010, 05:00 AM
2000jack's Avatar
1929 Chopped Tudor
Wiki Edits: 3
That makes sense to me and how I thought it would work, but other things have made sense to me and they proved not to work. Thanks
installing distributor/timing on sbc 350 075turbo Hotrodding Basics 38 05-19-2010 07:33 AM
Does anyone make a 12:00 timing tab for SBC TNshadetree Engine 7 02-04-2010 09:44 PM
Chevy SBC, finding TDC without timing marks 04SilveradoMykk Engine 2 10-25-2009 06:11 PM
SBC 355 Timing Question Fasazu Engine 7 10-16-2009 08:59 PM
timing light problems on sbc 4onthefloor 2 Engine 5 03-06-2005 07:47 AM
