does tv. cable come any longer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2010, 06:57 PM
candy63impala's Avatar
i have a s10 blazer here that someone swapped in a 94 4.3 but left the 700r trans. my question is i need to find a cable that is about 4-6 inches longer. the original engine had a center mount tb and the current has a front mount tb. the cable isnt long enuff to mount. is the any cars that you know of that have a longer cable or a replacement that is longer?
Old 01-27-2010, 08:22 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Chevy Astro vans, you could try something like a full size truck with the 5.0 or 5.7 engines, but the longest that comes to mind is the 82-84 Camaro with Crossfire injection.
Old 01-27-2010, 08:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
some of the tune port engine applications had long TV cables
Old 01-27-2010, 08:53 PM
you're probably better up fabbing something up that is the perfect length, as finding an OEM cable that is just the right length for proper operation is a pretty huge crapshoot.
Old 01-28-2010, 08:43 AM
SSedan64's Avatar
Get the longer Universal TV cable & adjust/cut to length. You can see both lengths here>> http://www.makcotransmissionparts.co...-700R4mis.html or measure your cable & see which you can use.
Old 01-28-2010, 08:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There isn't a clamped portion underneath or re-routing that will let you eek out that 4"- 6"?
I'm sure you've looked, but darn, a whole new cable for just that wee bit...
Old 01-28-2010, 09:55 AM
boatbob2
throttle cable.....
Hi,you can find an adjustable cable at NAPA..
Old 01-28-2010, 12:02 PM
fast68's Avatar
likes chevy trucks & boobies
many different length ones yes
also F body ones are an option.
Old 01-28-2010, 04:33 PM
thanks,i was thinking maybe a camaro or something would be a bit longer maybe. ill probaly pull it off tonight or tomorow and check napa
Old 01-29-2010, 06:08 AM
boatbob2
Old 01-30-2010, 02:32 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I have a TPI in my pickup with the 700r4 and the throttle body is at the front.
Watch out for adjustable cables.
I had one and the connection point to the pull cable at the tranny was hanging up and could not achieve full pull.
TV kickdown cable bracket lwin517 Transmission - Rearend 1 03-24-2009 12:26 PM
TV Cable Length Too Short? 700r4/2004r Cousin_Joe Transmission - Rearend 3 03-03-2009 03:06 PM
