Does upholstery always have to wraparound ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2004, 10:33 AM
This may be one of those questions I already know the answer to.
I'm working on a '67 Mustang street rod/track car, and re-doing the interior/dashboard in stock style but with higher quality materials.
The primary portion of the dash is a flat dashboard plate with a 90 degree bezel all around the edge that I'm recreating out of polished aluminum. The bezel is really visually important especially in my all black interior to set off the outline of the dashboard.
I'd love to have this dash plate covered in leather, but because of hte bezel I would not be able to wrap it around the edges. I would simply cut out a piece of leather and "flat" glue it to the dashboard plate.
In my mind the edges of this leather will be lifting up and curling back and probably sooner rather than later.
Is it possible to put down leather in this manner ?
(I"ve thought of other alternatives like making a border trim piece to hold it down - lots of extra work but a possibility !)
Old 12-21-2004, 01:22 PM
Max Keith's Avatar
wrap around
The problem with gluing it flat, as you pondered,will lead eventually to the edges curling up. What you could do if you are wanting to go that route, would be to make a retainer ring that will fit the face of your bezel, and will attatch to the bezel on the back side. This retainer would cover the edges of your leather insert, and keep it from peeling up eventually. This trim ring would have to be machined from flat stock and would be quite pricy. (billit machined)
If you have the room for it, you could also try using chrome C molding made for door edges, and slip this around the edge of your bezel, making a nice neat trim. Other wise, the trim ring I mentioned previously would have to be machined from flat stock and would be quite pricy.
Other wise you are stuck with folding the fabric over and affixing it on the back side.
Old 12-21-2004, 01:27 PM
Thanks - that is what I suspected. YOu have stimulated my imagination though, and I am going to attempt to figure out some kind of bezel/sealing ring.
Old 12-21-2004, 01:28 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I'm doing a similar thing on the door panels of my pickup - I am sinking the grilles on the 6" speakers into the panel so the vinyl must butt up against the grille. I simply cut the hole in the 1/8" plywood panel abut 1/8" over-sized and wrapped the vinyl around the edge and glued it. Now I have a very clean hole for the grille to nestle into.
Old 12-21-2004, 01:40 PM
Max Keith's Avatar
Youre welcome
Thank you.
Well I do have an edge on you in that respect. Ive been doing upholstery work off and on for the past 21 yrs. Guess you could say Ive been there and done that.
There are other options but most arent that satisfactory in appearance.
Have you considered going with a wood insert over the bezel rather than the leather. A real nice burly maple or some such with a good deep stain would look very ritzy.
When I had to fabricate an instrument panel for my old Angia, I used a piece of 1 X 4, using hole saws, I cut the holes for my guages, then stained the wood with regular Oxblood colored shoe polish.
I applied several coats and buffed the heck out of it. With a strip of chrome fender well welt around the edge, it came out quite nice.
The brand shoe polish I used was called Meltonian. Its a soft buttery type of shoe polish vs the waxy stuff by Kiwi. The out come was a nice soft luster to the wood. The Kiwi polish will come out with a harder shine to it, more of a glazed look.
Old 12-24-2004, 05:07 AM
New Member
Not an expert by any means, but my 2 cents:
Thin plywood the shape of the dash, wrap the leather around it..and a piece of foam if you want it cushy..
small holes in the dash, spring clips in plywood..
voila... a removable leather dash panel..
basically same set up as the original door panels in my 65 =) except they were vinyl...
-Michael
