Does it work? The "GrabIt" as seen on tv. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2009, 11:02 PM
DaSouthWon's Avatar
I put up the tools against$300
I was up at 3 o'clock in the morning a couple weeks ago and saw an ad for the "GrabIt" which is sorta the same thing as an EZ-out. It was $20 so I figured what the hell, picked up the phone and ordered it. It came in the mail yesterday and I gave it a shot today. I was surprised to find that it actually worked better than I thought it would. I pulled out 4 3" coarse thread deck screws that were stripped in a piece of oak in about 2 minutes. It wasn't advertised to work in steel but I figured I'd give it a shot anyway. It removed sheetmetal screws with no problem, but I was unable to remove a broken 1/4 in bolt that had broken of in a piece of 1/8" angle iron.
I obviously have no interest in the marketing of the GrabIt, I just wanted to pass along a review of a tool that actually worked and did what it said it would do. Sure there are many other products that do the same thing. But for $20 I figured it was worth the money.
Old 03-27-2009, 04:29 AM
yeah i was wondering bout those i striped the head of one the screws that holds the cap on my MSD dizzy had a hell of a time getting it out. had to buy a set of needle nose vise grips. cant figure why that was in there that tight. the ez out didn't do anything but make the head of the screw worse
Old 03-28-2009, 08:22 AM
I used it a few times, I've had limited luck with it (2/5 times)
I guess it all depends on how seized the fastener is, im sure if the screw or nut was in a softer material (ie: wood) it wouldnt have issues removing.
Old 03-30-2009, 10:27 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
slightly off topic, but I just used the craftsman 'bolt outs' (made in USA ) and they look like impact sockets, but have a spiral design inside... 3/4" head bolt holding a skidplate in a 96 Jeep in the rust belt... with a breaker bar it removed the rounded bolt without hassle.
...the grabit works from the inside (like a screw) so I dunno... odd...
Old 03-31-2009, 10:50 AM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
I've had to use one that a co-worker keeps on himself at all times many times, and it was excellent to use. But, they are not really intended for steel-to-steel uses. For use proper applications, they are indispensable.
In a while, Chet.
TV cable issues on 200r4 Roy_67_SS350 Transmission - Rearend 2 09-15-2003 11:55 PM
