DOHC on CHEVY 350? POSSIBLE? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2010, 05:45 PM
XeroVolume's Avatar
Just for fun, I was wondering what all might be involved in running Dual Overhead Cams or even a Single Overhead Cam with an early model Chevy 350 CID engine. Has this ever been attempted? Is it even possible?
Old 01-31-2010, 05:51 PM
XNTRCI-T's Avatar
AKA Lee in KC
Never mind.
Old 01-31-2010, 06:00 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
I have read about a couple companies that have made heads or maybe i am thinking 3 or 4 valve heads. But either way they are big $$$$$$$$ though. Do a google search for it.
Old 01-31-2010, 06:30 PM
If I was a millionaire I may try that for fun. Maybe there is a 4cyl gm motor with the same head bolts, water passages, and bore spacing? I'm interested now... If one of the big three just used the same spec from half a v8 for an inline 4 I think it would be GM. If you want you could check head gaskets at the auto parts store? Head bolts are a biggie.. water passages and oil can be routed for a one off. I would start off with a old 2.5 inline 4 and compare the head gaskets. Got a friend at the auto parts store? or go in when they are slow and keep comparing head gaskets?
Old 01-31-2010, 06:31 PM
What is funny is a volvo DOHC will fit on a 2.3 ford motor with some modification. It really isn't that horrible...
Old 01-31-2010, 06:37 PM
Listen and Learn
Wiki Edits: 7
lol thats strange. I have read that the GM LS series heads will bolt onto a ford windsor 302
Old 01-31-2010, 06:48 PM
That is just plain hilarious if it is true..
Old 01-31-2010, 06:52 PM
Check this out! http://forums.hybridz.org/showthread.php?t=158418
Old 01-31-2010, 07:07 PM
Those guys were talking about filling in block areas and taping for head bolts! That would be a serious feat to weld that to work without cracking and or warping..?
Old 01-31-2010, 07:21 PM
ericnova72's Avatar
More for Less Racer
Not Overhead Cam but 4-valve cylinder head for SBC, BBC, SBF at www.araoengineering.com Nelson Racing Engines has a video in their gallery of Arao heads on a supercharged 406 SBC that is something to see www.nelsonracingengines.com Heard through the net that delivery is very slow from Arao.
Moser Engineering did a OHC conversion on the SBC in the 70's.
Old 01-31-2010, 07:58 PM
Listen and Learn
Wiki Edits: 7
I forgot about the LT5!! 32 valve DOHC 350! Ugh can you imagine doing a valve job on those heads.
Old 01-31-2010, 08:16 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I remember some time, I think the mid 80s, there was a company making a DOHC 32 valve conversion heads for SBCs, I can't for the life of me remember the name of the company right at the moment, (CRS disease, ), but if I do, I'll post it,
The Following User Says Thank You to Rickracer For This Useful Post:
zmaxmotorsports (03-05-2013)
Old 01-31-2010, 08:28 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
The LT5 was a completely different, one-off design though. It is more closely related to the Northstar and Aurora V8s that came after it than with the more common Gen I and Gen II SBC V8s.
Old 01-31-2010, 09:23 PM
gas_guzzler's Avatar
Do a search for Weslake chevrolet heads. I saw a pair of these for sale a couple years ago, pretty sure they were 4 valves per cylinder. Very expensive and rare. I think they made ford v8 ones too?
Old 02-01-2010, 01:39 AM
ENGINE
350 c.i. V-8 ZR1 LT5 lotus designed and bult by mercruy marine.
C.R.
11.0:1
Horsepower
375@5800
Torque
370@4800
Acceleration
Sec.
0-60 mph
4.9
Standing 1/4 mi.
13.4@109 mph
It is amazing how much performance has changed in last 20 years. It only cost $58,995. What would that be in inflated dollars.
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
350 chevy heads question pena0724 Engine 7 03-02-2009 06:09 AM
350 chevy pena0724 Engine 2 02-17-2009 08:04 PM
350 Chevy in a '73 TransAm Lawngodfather Engine 6 06-10-2008 08:08 AM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
