| Register now (free) or login to remove ads | |
Tweet
#1
Doing my own door panels with flames
Bare with me
I have already searched the forum and the KB and have found nothing on doin' this so i'll just ask Congratulations you have made it to the end of this post |
| Sponsored Links |
#2
Heres a quick search that yielded a couple posts that might help.
http://hotrodders.com/search.php?s=...rder=descending |
#3
Krist, yours wouldn't locate a thread.
60Buickrod, try these and see if they help: http://hotrodders.com/showthread.ph...or+panel+flames http://hotrodders.com/showthread.ph...or+panel+flames http://hotrodders.com/showthread.ph...or+panel+flames Dutch |
#4
Super simple if you know what you are doing. if you dont want to sew you can use a glue down process. I prefer a combination but it depends on what you are trying to do.
Glue method only: The key is layers. You need to decide on the design you want and then the section (how deep and high you want each layer) This will depend on the door edges and interface with the seat and dash. You start with the lowest layer that is the base panel and then the highest layer closest to set and body. Each layer can be done out of simple insullation boards for housing (pink normally). I usually sand the edges to make them smooth and tapered to suit the design. Materials dont make 90% complex contours without some practise and forgiving material (lots of stretch). Use contact cement (for formica) to put them together. You can make the flame high or low depending on the design you want. then working from the lowest point on a recessed design or highest point from a proud designs work from the the most complex area out. If you need more information let me know |
#5
The flames are going to be very simple. My car has a vent window crank, window crank and the arm rest, and I'm going to do single layer flames coming off of them about 3-5". I've got a picture of it somewhere, I'll post it if I can find it
