Dome or Flat Top - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2011, 09:23 PM
Dome or Flat Top
OK, Today I ordered my aluminum heads to go on my 70 LT-1 motor
I have one cylinder that I dont like so it will be bored .30 over
Everyone tells me to use flat top pistons because of our gas but I am stubborn and want to stick with domes. Especially since I have pink rods and all the good stuff from long ago
I will be running solid lifters, I know but I like the clicking sound
You guys are smarter than me so I will listen
This will be a driver only car and probably less than 2000 miles a year. Even less if gas keeps going up
Old 04-22-2011, 09:29 PM
My Mistake
I found the answer in some other posts so I will go with the flat tops
Thanks
Old 04-22-2011, 09:58 PM
CJ_1080's Avatar
known to do dumb stuff!!
Domed pistons can interfere with proper flame propagation. Always try to use flat tops and smaller chambers when possible!
Old 04-22-2011, 10:20 PM
The mobile view is crap
if you have to buy new cylinder heads I would try to buy a large enough combustion chamber to use flat top pistons while remaining proper quench height of .041 to .061 for a daily driver, the closer to .041 you can get the better of it will be. Flat tops are better at resisting hot spots on the piston due to better flame travel across the top of it. This is why the hemi engine has never really been a "reliable" engine is due the the HEMIspherical shaped combustion chamber requiring domed pistons to get any compression out of it. The HEMIshpherical shaped combustion chamber is a good idea for creating power but not worth the domed pistons. If you need to run a dish piston to lower compression ratio the best choice is probably Keith Blacks D-shaped cup pistons which put all the dish to one side to keep the "quench" area flat for better atomization of fuel.
I don't understand why you are only boring one cylinder though? Are you saying you are going to buy all the pistons individual? Or are you buying a set of 8 pistons and 1 single piston? Then you are going to buy 2 ring sets? If you have the rotating assembly balanced, which you should, they are going to have to take an extra amount of that one piston to balance the engine. I would just bore all 8 cylinders that way they are all the same.
As far as the solid lifter, why? For just a daily driven car that is going to only see a few miles a year why would you want the maintenance of a solid lifter if you don't have to? Just clothespin a playing card to the fan blade like we used to do to our bike spokes when we were kids.
I would be interested in your complete specs of everything for this engine and what you are looking to get out of it
Old 04-22-2011, 10:54 PM
techinspector1's Avatar
Wiki Edits: 326
Building with flat tappets these days is a roll of the dice, so do everything you can to insure longevity. Please read this....
http://www.crankshaftcoalition.com/w...ips_and_tricks
http://www.proracingsim.com/dynosimmainpage.htm
Old 04-23-2011, 05:33 PM
Boring one cylinder
I will not do anything half assed so I am boring all cylinders even tho only one is bad
I am an old fogey and love the sound of solid lifters. I was lucky enough to have bought a new, straight from the showroom 1970 LT1 and I loved it but jr came along so everything was on back hold til he was grown
I have a daily driver Honda and this Vette + a 98 Pace Car so it will not get much riding
Now days I cannot hot rod a car cause if something breaks I may not be able to replace it
Old 04-23-2011, 05:36 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Great choice on the flat-top's that is how i would have went also.
You need to post up some pics of your vette also.
Cole
dome pistons vs. flat top philr Engine 23 12-15-2012 01:50 AM
hydraulic flat vs mechanical flat sexypizzaman Engine 20 10-16-2009 01:10 PM
Hydraulic flat Tappets, roller or Mechanical flat tappets? bartamos Engine 6 04-09-2008 10:00 AM
help with 350 bottom end build-up. flat top or .10 dome? cast hyper or forged? 74chevyflat Engine 5 11-03-2006 07:40 AM
? about dome piston's bowtieorbust Engine 5 09-19-2004 07:34 AM
