Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dome light
Thread: dome light
Old 07-12-2012, 05:24 PM
jmacs53Willys jmacs53Willys is offline
You can always go with a grommet through the floor , under the cab and then back into the cab if you can get to the floor? Of course you will want to use some plastic wire wrap to protect the wire from the elements and whatnot. Remember that if you want to use door buttons to activate the light, the buttons are the ground side of the light. That way there is no positive power at the door button, it just makes the ground for the light when doors are opened. Your power can be from a full time fused positive terminal, switched or unswitched, or like you want, a toggle. If you are just going with a positive and a negative two wire install then passing the wire through the back of the cab will have to be basic wiring 101. Hope this helps. Jmac
