dome light - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2006, 06:54 AM
dome light
does anyone know what i should do about a dome light in my 73 road runner that wont go out even when the doors are shut?
thanks-rrmike
Old 03-10-2006, 07:12 AM
Have you checked your door switches yet? When the door is open, the switch completes the dome lamp path to ground. So if the are staying on, check and make sure the switches are open when pushed in ( and not stuck in). This may sound stupid, but make sure the switch (headlight) isn't al the way to the right in the dome lamp posistion and that this switch is completing the ground circuit for the lamp. Hope this helps. Maybe Doc will be along with a schematic for you.
Old 03-10-2006, 07:43 AM
ok ill check that
thanks-if you have a schematic id be gratefull.
Old 03-10-2006, 09:07 AM
Holly-Roller's Avatar
*special* member
You don't need a wire diagram for something this simple. If the door jams aren't pushed in, and you lights aren't on, just remove the dome light, and simply fallow the wire untill you find the short.
Old 03-10-2006, 03:18 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Don't have a Schematic for a 73 Road Runner, but I can tell you how it is wired, and the most probable cause for this situation.
The Dome light switch is wired Direct from a Fuse on the Fuse panel. On the other side of the Dome light socket, there is a white wire that goes to the Door post switches, in a daisy chain arrangement. That same wire goes back to the Dome light portion of the light switch.
If you pull any switch out of the door post, you will see that the switch is a one terminal switch, center conductor. This is because the second terminal is actually ground of the switch body where it contacts the door post.
When the door opens, the switch being spring loaded, pushes the center contact forward to the switch body , Completing the ground circuit. Thus, the light goes on. When the Door closes and contacts the switch plunger, it pushes the center contact AWAY from the switch ground, thus, the light goes out.
First, Carefully pull all the switches out of the door posts, they should just slide right out.., so that none are on ground. The dome lamp should be out. If it is , Replace the switches one by one until the light comes back on again, this will be a defective switch. Replace as needed.
If the light does not go out, Then you have a short in one of two places, the wire going from the lamp socket to the switches, or the wire going from (Usually) The left front switch , to the headlight switch. Pull the wires off the left front switch and see if it goes out, If so, then you have to troubleshoot that wire and correct it (shorted to ground) .
If it does not go out, then you have to repair or replace the wire between the lamp socket and the first switch in the chain. (have to fish the headliner )
In somewhat rarer Cases, the headlamp switch Dome function could be bad also.
Doc
Old 03-10-2006, 06:00 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
The attached is a sketch of a typical dome light that will support the above posts.
vicrod
Old 03-10-2006, 06:08 PM
Wiki Edits: 31
my '51 Chevy is doing this too, I have to shut the switch off manually with the switch on the dome. pushing the switch on the driver side makes the light flicker, so I just need to clean the ground contact
Old 03-10-2006, 08:18 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Is there something in the air? My '97 C1500 dome light (delay light ) was just on and wouldn't go off fo rnothing tonight too. Went to work for bro-in-law, got back to the truck after dark and lights were still on. Once I got it running, the lights went out, but the lights both overhead and on the doors flickered on. I was home for almost 45 minutes before I must've slammed the truck enough to get it to stay dark. Even the dome override wouldn't help.
Thanks for the info Doc, Chet.
Old 03-10-2006, 09:12 PM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Getting there
My 95 Tahoe had the lights going on for no reason all the time. I changed all the door switches and haven't had the problem at all
Old 03-10-2006, 10:19 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Next time that happens...And you have to leave it to go to work...
Multiple Choice on how to avoid a Dead battery.....
  • A) Ignore it and hope the Gremlins that turned it on in the first place will shut it off...
  • B) Pull the Dome light Fuse
  • C) Pull the Dome lamp out
  • D) Have the wife run out to the garage every half hour and start the car..
  • E) Both or either C or D above
The Correct Answer is E...Both C an D above..
BUZZZ...."Correct! Thank you for Playing...You've Been a Great Contestant.."
"Johnny...Tell them what they have won...."
"For Winning our Question today..."
"You and a Guest have won a 3 day 2 Night (and possibly an eternity) Stay at the Beautiful Bates Motel..In lovely Downtown Barstow California.."
"You Will Feast on a Dinner of Square Cut Peanut Butter and Jelly Sandwich's, and Milk..
After which you will tour the Bates Taxidermy Musuem..where not only the Guests are stuffed after dinner..
Then on to the Mother Bates Comedy Club..Where Mother Bates will Keep you in Stitches with her Cutting humor...Then top off your Evening, in your room for a relaxing Shower...
(*Norman! What have you done now?...Scrrreeeech Scrreeecchhh..)
Back to you Bill...."
Sorry..Had to Get in my Friday night Grins...
Now back to our regularly Scheduled Program...
Doc
Last edited by docvette; 03-10-2006 at 11:05 PM. Reason: Cuz I can..Hewlet Drinks..Packard Enables Him...
Old 03-10-2006, 10:41 PM
docvette's Avatar
Wiki Edits: 12
Doc Here,
Doc
Old 03-11-2006, 05:54 AM
Ratdoggy's Avatar
Usually it's the simplest and easiest solution
Old 03-11-2006, 06:18 AM
2000jack's Avatar
1929 Chopped Tudor
Last wiki edit: How to title a hot rod
Last journal entry: 1927 roadster
Wiki Edits: 3
thanks-rrmike
Have you tried to take the place of the door? That is push the switch into the jamb by using your finger. If that is it then readjust the switch towards the door. I vaguely remember having this problem once. I think that the engine vibration had loosen the switch or something. Anyway it could be as simple as that.
Old 03-11-2006, 01:06 PM
schnitz's Avatar
Wiki Edits: 54
Mrs. Schnitz here (yet again...)
Ummm.....no!!!
How does a dome light wire up Ed ke6bnl Electrical 2 01-14-2006 07:37 PM
How many rodders does it take to change a light bulb? Dusty82 Hotrodders' Lounge 6 09-01-2005 10:02 PM
Dome Light - Grounding Question horvath Electrical 5 05-15-2004 09:31 PM
dome light distress draliengt Electrical 1 02-02-2003 12:15 PM
Dome light thinks its on a timer 78 monte Electrical 1 06-25-2002 01:11 PM
