Dome Light Wiring question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2010, 04:01 PM
I installed an EZ wiring harness in the 56 1/2 ton. I,m having a senior moment regarding the dome light wiring. The harness has a white wire coming from the fuse panel, it is a constant hot. I wired it to the prong on the headlight switch for dome light return. There is a black wired ground (?) prong on the headlight switch that is hot when the switch is turned on ? I have no door switch and just want to be able to turn on the dome light with the headlight switch. Can someone tell me how to wire this? Thanks
Old 10-17-2010, 07:45 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Typically dome and courtesy lights are wired to the lamps hot at all times and switching control is done to ground.
When the headlight switch is rotated fully it makes a connection to ground which will complete the circuit and light the lights.
A ground wire connection is required at the headlight switch for it function.
The white wire that comes from the fuse block would go directly to the lights.
Another wire would return from the lights to the headlight switch.
vicrod
Old 10-17-2010, 08:19 PM
Thanks, the instructions were a little vague. I was running the white wire to the switch, not the light itself. Duhhh
Alternator/Voltage RegulatorTerminal "ID" And Idiot Light Wiring Viet Nam Vette Electrical 1 05-11-2008 12:40 PM
Tapping into dome light circuitry 2006 Lincoln Mountaineer Rambo_The_Dog Electrical 6 06-27-2007 08:39 AM
Tail Light Wiring Theresa Shank Electrical 16 06-11-2007 09:35 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 03:28 AM
Another dome light/headlight switch question. schnitz Electrical 8 03-30-2006 07:14 PM
