My 461 BBC in my S10 has the LS6 pistons (Speed Pro L2349F) running a closed chamber head. As far as the rods, just replace the stock rod bolts with ARP and you'll be fine.
SRP 212135 (+0.030"), 23cc dome, yields 9.9:1 with 118cc chambers on a 454
SRP 212136 (+0.060"), 23cc dome, yields 10.1:1 with 118cc chambers on a 454 SRP 212138 (+0.100"), 23cc dome, yields 10.3:1 with 118cc chambers on a 454 SRP 212135 Forged Small Dome Profile Pistons 4.280 Bore | CNC Motorsports | Car Parts | Truck Parts | Competition Engines Your cam closes the intake valve @41 degrees after bottom dead center. On the KB calculator, using 9.90:1 SCR, the dynamic compression ratio of your motor would be 8.446:1 At 10.1:1 SCR, the DCR would be 8.614:1 Your current DCR with flat-tops is 7.108:1 Last edited by techinspector1; 10-24-2012 at 11:57 PM. |
add a blower
Here is a simple on I use some times.
Wallace Racing: Dynamic Compression Ratio Calculator Here is a more complex version. United Engine & Machine Co. Incorporated Last edited by hcompton; 10-25-2012 at 06:44 AM. |
Buy the right pistons, don't cut the heads to try to bring the compression up. If you get the compression arount 10-1 you will have a good performance street engine. 454s don't like to run with any less than 10-1. As far as your 781 heads go, don't open the intake side other than cleaning out the casting flask and don't install bigger valves. The exhaust side install 1.88 valves and port match. 2.06 1.88 781 head is an awesome combination on the street. This will make the engine more efficient, BBC have probelms breathing on the exhaust side rather than the instake side of the motor. Don't install closed chamber heads, you will be giving a lot away. I they make Hypereutic pistons you can get on Ebay for around 300.00 a set, rods for about 200.00 with arp bolts, cheaper than the local machine shops at least where I live. Just a few suggestions from my experience, but opinions are like ? Good Luck!
Dome piston 454
You didn't do your research before you bought your heads did you! When using flat tops in a 454 you need a set of closed chamber heads with a 96.0cc chamber. This will net you about 9.7 compression ratio and a DCR of 8.279 which is good for running pump gas. Here is a partial list of heads that can be used. 3856206, 3872702, 3904390, 3917215, 3931063. These are closed chamber heads with 98.4cc chambers. Have them milled to 96cc. Also 3909802 and 3964290 are 100.9cc chambers just more to mill. You would have to check the intake and exhaust valve size since most of these are truck heads. If you want to use the 781 heads you have, Keith Black has the Icon Forged Pistons IC779 with a -18cc dome for 9.5 compression. Also there is the IC782 with a -27cc dome for 10.3 compression with 118cc heads. Here is some advice on the type camshaft you should use in a big block. With the mechanical flat tappet you don't have to worry about wiping cam lobes during breakin and the bring the performance out of the big block chevy. http://www.summitracing.com/parts/cc...make/chevrolet
You will be waisting your time and money if you use closed heads. Spring for the right pistons.
Dome pistons 454
Check out these Eagle rods. Eagle SIR I-Beam Connecting Rods 6135B - SummitRacing.com I have used them in my 454 for three years with no problems. I recently stroked my 454 to a 491 using these rods Eagle ESP H-Beam Connecting Rods 6385B3DL19 - SummitRacing.com and the Icon forged pistons and the 4.250 eagle forged crank.
You are right, if you are starting from scratch. Might as well stroke it. Good Call! But the same rules apply. I believe in EnginesMasters a few year ago they did an iron headed 496 with merlin heads it made just over 700 hp on pump gas. They had a lot of nice stuff in the motor but you can build moderently cheap 496 and make 550 to 600 hp. Nothing is cheap anymore!
Here's a cheapo 505 that I dyno-simmed 3 years ago. It's still fun to look back on....
Cheapo BBC 505 tall deck grunt motor |
Should I try to go for the 10:1 compression or lower? The risk of detonation with pump gas is higher right? And bigger valves would make more power but at a cost of effenccy ? And to cdminter I have thought about it, I'm willing to go all in man plus forged pistons will allow me to run a small nitrous kit. But Which dome piston should I get? All this info helped alot guys thanks
Dome piston 454
The 18cc dome piston IC779 will give you about 9.621 compression with 118cc chambered heads. If adding a nitrous kit I would stay below 10.0 compression with iron heads. What do you mean by go all in? Is the short block of this motor assembled? I will send you a PM.
| milling dome on piston | price | Engine | 2 | 11-10-2007 12:41 PM |
| ? about dome piston's | bowtieorbust | Engine | 5 | 09-19-2004 07:34 AM |
| piston dome | firestone | Engine | 2 | 02-19-2004 06:51 PM |
| piston dome cc | Wrencher | Engine | 4 | 09-18-2003 07:39 AM |
| Piston Dome cc's? | Venturat | Engine | 1 | 01-14-2003 02:21 PM |
