Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dome pistons vs. flat top
Old 12-12-2012, 06:22 AM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by philr View Post
I was just wondering if you had a 350 with a small dome piston with 10-1 comp. and a flat top piston with 10-1 comp. Same heads same cam and everything which one would run the strongest with a quench of .035.This is something I was just wondering and ther e may not be an engine like this. I waas just wondering how much the dome hurts the power. Thanks philr
the dome pistons will have more compression. But yes flat tops are best for 350 engines with 64 cc heads.
4 valve reliefs are cheaper since they fit on both sides 2 need to be different on each side. so it cost more.
dome can hurt power if the head is not right for it. with 64 cc heads its not real easy to buy proper dome pistons that are not in the 12:1 range. BBC and hemis run domes with great success but requires a little know how.
