Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dome pistons vs. flat top
Old 12-12-2012, 07:59 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
kind of what mouse fink said. If you have a short stroke engine (283,289) you will need a dome to make compression,with a long stroke engine things change the other way,like if you build a 434.
you need to find the correct combination of heads and piston design to fit your application and displacement.
