Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - dome pistons vs. flat top
Old 07-10-2005, 09:17 PM
HemmiGremmie's Avatar
HemmiGremmie HemmiGremmie is offline
Last journal entry: 52 truck
If your trying to keep the comp ratio at around 10-1 or so, then use the flat tops.
Flat top pistons will have a better flame travel than a domed piston, so only run domed if your trying to get the comp ratio up higher. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
