dome pistons vs. flat top - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2005, 08:38 PM
I was just wondering if you had a 350 with a small dome piston with 10-1 comp. and a flat top piston with 10-1 comp. Same heads same cam and everything which one would run the strongest with a quench of .035.This is something I was just wondering and ther e may not be an engine like this. I waas just wondering how much the dome hurts the power. Thanks philr
Old 07-10-2005, 09:17 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
If your trying to keep the comp ratio at around 10-1 or so, then use the flat tops.
Flat top pistons will have a better flame travel than a domed piston, so only run domed if your trying to get the comp ratio up higher. HG
BigDawgsEatFirst's Avatar
400SBC4Life
I would put money on the flat top, with a quench of .040 the flat top would provide a better squeeze into quench area providing
combustion efficiency.
Old 07-10-2005, 10:19 PM
347mustang's Avatar
flame travel is what makes the plain o flat top motors run so good
Old 07-11-2005, 01:43 AM
Flat tops are often lighter then a dome top too...
Old 07-11-2005, 05:49 AM
A dished piston will make even more power than a flattop if the quench is the same, better burn and more force on the piston's center. This would be a good test for a magazine to do, build three engines, all the same exact compression ratios, same piston to head clearance, but with different head chamber sizes and pistons to quanify the differences in burn rate and resulting power differences. The only variable would be the flow efficiancy of the heads- most open chamber designs flow bettern than small chamber designs. But a flow test could reveal those differences and adjustments could possibly be made to equalize the three. Bob
Old 07-11-2005, 04:31 PM
Going to use flat top piston
I am going to use the speed pro flat top piston with 2 valve reliefs.It will do better with pump gas.I can get the quench correct maybe it wont ping and it will run better. philr
Old 07-11-2005, 06:18 PM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
I have two questions:
1. What is 'Quench'?
2. How many different piston types are out there? e.g. Flattop, Domed, Dished etc.
Old 07-11-2005, 11:06 PM
lluciano77's Avatar
Short changed on common sense
Search in the HotRodders Knowledge Base for "quench" It is in there.
Dome pistons are an airflow restriction. Flat top pistons are the best flowing.
Old 07-12-2005, 12:56 AM
Malibu73's Avatar
What about dished pistons?
Old 12-12-2012, 02:15 AM
Does it hurt to use a wire wheel on cleaning the top of a flat top piston?
Old 12-12-2012, 05:24 AM
Were can you find domed pistons that will produce 10:1 compression ratio?
Every domed piston I have seen produce at least 11:1 compression ratio compared to the same engine with a flat top piston.
Old 12-12-2012, 06:00 AM
Yes, can leave scratches. It is better to use a type cleaner that is compatible with aluminum. GM Top Engine Cleaner is a good cleaner. Soda blasting is another way.
Old 12-12-2012, 06:22 AM
Old & Furious
the dome pistons will have more compression. But yes flat tops are best for 350 engines with 64 cc heads.
4 valve reliefs are cheaper since they fit on both sides 2 need to be different on each side. so it cost more.
dome can hurt power if the head is not right for it. with 64 cc heads its not real easy to buy proper dome pistons that are not in the 12:1 range. BBC and hemis run domes with great success but requires a little know how.
Old 12-12-2012, 07:59 AM
vinniekq2's Avatar
kind of what mouse fink said. If you have a short stroke engine (283,289) you will need a dome to make compression,with a long stroke engine things change the other way,like if you build a 434.
you need to find the correct combination of heads and piston design to fit your application and displacement.
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Keith Black Pistons Problem tornado-tech Engine 17 11-16-2004 10:04 AM
crap on top of pistons Troy Hotrodding Basics 11 02-22-2004 06:27 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
