dominator air bleeds - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 06:31 PM
Last journal entry: PICTURE TEST
Anybody know what the stock sizes of the air bleeds are on a 1050 dominator??? Near as i can tell it's a 6464 list. It has the intermediate passage in it.
Right now the idle air bleeds are .035" and the intermediate air bleeds are .100"
The carb is real fat right now... it was supposed to be a perfect working carb...But at idle and even up through 3500 rpms or so,, it still blubbers.... I do not have a dyno only a test stand...
I am thinking the 2 air bleeds are backwards... The .100" should be in the idle location and the .035" should be in the intermediate location??
Any thoughts??
Old 12-26-2006, 07:06 PM
They would appear backwards. A two circuit would be in the 70 idle and a mid 30 high speed.
Old 12-26-2006, 08:11 PM
Bumpstick's Avatar
Hammer and a torch
Yep the smaller they are in size the richer it will make the circuit...
Old 12-26-2006, 08:57 PM
Mark, I looked through my air bleed spec sheet for Dominators and don't show a 6464 list number.
In general though the idle bleeds are generally in the low 40 to mid low 50 range and the intermediates are in the low 60 range. Hi speeds range in the 28 to 40 range. The R80586 is an oddball with the idle bleed at 28.
If you have the full list number that begins with an R I can look up the exact specs for you.
Old 12-26-2006, 09:43 PM
Bumpstick's Avatar
Hammer and a torch
I think if I remember correctly the 6464 was for dual carbs for a tunnel ram...? I had one once before and really liked how it performed even in single setup...
Old 12-26-2006, 10:01 PM
I found the list number in another part of my book but it doesn't list the air bleeds. Only jetting info is pri and sec mains, 88 square stock.
Old 09-20-2011, 09:27 AM
My stock air bleeds are 53 idle ,63 Intermediate/ 40 highspeed
I knoe its lateinfo but thought it might help.
Screw in air bleeds same for Holley and Demon?? hotrodf1 Engine 0 10-13-2006 09:11 AM
Air bleeds Holley HP (idle & main) Bumpstick Engine 0 07-14-2006 07:38 PM
Holley adjustible air bleeds and IRF question 70bird Engine 13 12-05-2005 07:54 AM
Possible Airbleeds Too Big HELP!!! swampwillie Engine 3 07-18-2005 05:43 PM
need info on air bleeds for 650 speed demon brian400ex Engine 1 07-01-2005 08:09 AM
