Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dominator review thread
  #73 (permalink)
Old 12-09-2010, 11:00 AM
Dominator2 Dominator2 is offline
DENT REMOVAL SYSTEM
BRIEFLY DESCRIBED: The Dominator2 is an 'air tool', that is PART of a SYSTEM that I invented. I am a 20 year PDR Tec, and life long bodyshop tech. This SYSTEM has actually (4) components.
1. Hydraulics used with 'carpet blocks' for pushing out LARGE collision type damages (www.************.com go to videos and then to 'how to make a carpet block'.
2.The pneumatics is used with large suction cups on a heavy slide hammer.
3. The GLUE SYSTEM is the KEY factor in removing large damage. Our glue system has three different types of heads. All of which are perforated. Once the pads are glued to the vehicle the glue penetrates through the pad and changes the physics of how strong glue can hold. The pads can then be lifted via a leverage bar, or slide hammer. Multiple pads can be pulled 'simultaneously' for pulling large damages.
4. THEN the LAST part of the dent is then FINISHED via paintless dent repair or the Dominator. The dominator Has interchangeable heads made of stainless steel that spin at 20,000 RPM taping the backside of the dent moving the metal up incrementally.
Last edited by Jon; 12-10-2010 at 11:58 PM. Reason: Advertising. Please see: commercial posting guidelines.
