Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Dominator review thread
Old 01-26-2006, 06:35 PM
Dominator2 Dominator2 is offline
DENT REMOVAL SYSTEM
Using the tool.
Brian. Your probably going at it way too hard. The tool will do the work so you don't have to 'bare down' on it. Also, rotate the tool in a circlar motion as your woring the dent, and lastly, you GOT TO have a PDR light. I am sending a 12 volt to you. IT'll work, but, to REALLY see, you need a good light. Get the tool going at top speed, and then slowly bring it up to the underside of the metal while your going in a cirular motion. Practice, by writting you name in the panel, keep doing it, then slowly start making it lighter, and lighter, till you can barely see your name being written. Once you can 'see' what your doing you got it! Good Luck
