Donor for a 5 or 6 speed trans (GM) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2010, 11:17 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
I'm looking to swap out my auto trans for a manual unit in my firebird. Looking for a new trans is a bit of a depressing proposition as all the new 5 and 6 speed performance transmissions are thousands of dollars. Are there any stock units out there that would be worth the trouble? I'd like to have an overdrive gear to reduce the highway RPM of my 3.73's...
Thanks guys-
K
Old 02-02-2010, 12:49 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
You should be able to find a Borg Warner 'world class T-5' that actually came in some of the third gen F-bodies.
Old 02-02-2010, 03:54 PM
Wiki Edits: 3
Thanks, I'm working with a second-gen but i'm sure I could make it fit. Are those transmissions worth the trouble? Can they stand up to 400+ horse?
K
Old 02-02-2010, 10:26 PM
ericnova72's Avatar
More for Less Racer
The T5, even a world class version, will not live long if driven hard at your Hp level. You are looking at needing a Tremec or a T56 6-speed at your power level.
Richmond 5 speed trans Hot Rod Mike Transmission - Rearend 15 09-02-2009 03:22 PM
2 speed powerglide trans 64r1 Transmission - Rearend 2 08-03-2007 11:29 AM
GM Gutrag(???) 5 speed schnitz Transmission - Rearend 8 03-25-2004 09:27 PM
m49 5 speed trans diagram????? gibbo Transmission - Rearend 0 03-12-2004 02:50 PM
GM 6 speed - shifter chevypu Transmission - Rearend 1 03-13-2002 06:21 AM
