Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Don't answer the phone!
Old 12-06-2012, 01:51 PM
delawarebill's Avatar
delawarebill delawarebill is offline
take a deep breath 27...
and start over... go to TDC and re-adj the rockers for that stroke. make sure they are pumped up first. adj and spin the push rod till it stops turning then turn another 1/2 to 3/4 turn. then turn the engine one full turn and do the other half of the rockers. if u know for sure your on TDC #1 set dizzy to #1. u may want to pull the timing cover to fix first cause u gotta drop the pan too.
The Following User Says Thank You to delawarebill For This Useful Post:
27Tall T (12-06-2012)
