Do you have a reserve canister with a 1 way valve? 10hg is way low but if it ever gets higher it'll stay in the can. I have 10hg at idle which doesnt hold my brakes but my reserve can gets 18hg after a few revs.
i had that problum and changed the canister solved the problum the canister was colapsing just enough to cause problums
For real ? that must be one huge cam, blower. Was this a manual brake car before ? I can not tell what all you changed, but if you did change the booster there should be a bit of free play in the peddle before the booster is activated. If not it will never build vacuum . Hard peddle no vac assist period, too check. Engine off, put foot on brake peddle, with pressure on the peddle just start the, engine if the booster is working the peddle will go down some. That tells you the system, booster is working. Where are you getting the vac from, carb or manifold? Manifold is best, a carb has what is know as a timed port that does not have a vac signal at idle , a common mistake. Start there |
But of course this shouldn't be even thought of until your vacuum source is verified. Brian |
| Pinging on cruise part throttle acceleration? | kyle86 | Engine | 56 | 07-25-2010 07:30 PM |
| timing question | Radchop | Engine | 7 | 11-19-2008 09:16 PM |
| Vacuum adv.. | underdog305 | Engine | 58 | 01-30-2007 11:19 AM |
| 68 charger lights | T-bucket23 | Electrical | 5 | 08-14-2006 05:07 PM |
| Ported Vacuum | 72Orange | Engine | 18 | 08-07-2006 08:56 PM |
