door adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 08:53 PM
door adjustment
Helping a friend adjust door on 88 monte after he changed hinges and the strike pin caught the door while trying to adj. it and cannot release the door . It clicked once and won't release . Any tricks to get the door open to finish up adj.? It's real close to being in the right spot ! Thanks for any help !!!
Old 04-22-2013, 09:18 PM
That is a hard one, once it gets stuck, you are stuck.Do you have any idea of how it was hitting, was the door high or low? Forward or back you can still see. Look at your gaps, is the front much larger or smaller than the back? It often is the striker being caught in the latch, not that the latch won't come unlatched, it's that the striker is wedged into it.
So first report back here as to were the door may be.
Old 04-23-2013, 07:36 AM
deadbodyman's Avatar
Wiki Edits: 11
If the panel is off its ezjust reach down and unscrewthe strikerfrom inside but chances are its just jamed up so while holding the handle up have someone push open the door (real hard)from inside,you may need a pry bar...You always remove the striker before trying to adjust a door ,when it fits and gaps are good then you replace the striker...... last.
sounds to me the door is to far back and wedged the door between the striker shims....
The Following User Says Thank You to deadbodyman For This Useful Post:
tech69 (04-23-2013)
Old 04-23-2013, 07:48 AM
We had the door lined up good and were just trying to see where the striker should be moved to and the first latch clicked . That's where we left it as we ran out of time but it didn't want to let go of the door !
Old 04-23-2013, 09:01 AM
Well that does sound like it's just the latch. Inner trim panel on or off? As DBM said if the panel is off you should be able to get in there and release it. It sound like there is something a little bit more going on here.
Old 04-23-2013, 10:17 AM
put up or shut up
sounds like the striker is binding the latch but the latch isn't really jambed so to speak. DBM has a great solution. Don't even hesitate to have the guy use his feet while you're holding the handle button and pulling with the same hand. It should fly right open. Sometimes you'll have to kick that darn thing open.
Old 04-23-2013, 05:36 PM
Thanks guys !! He had it open when I stopped by today and we finished it up !! He was happy and was happy for the help ! Works good !
48 chevy p/u door adjustment cornfieldcars Body - Exterior 11 04-14-2011 08:59 PM
Drivers door adjustment? Madmax305 Body - Exterior 6 03-27-2010 11:22 PM
door adjustment prs Body - Exterior 13 05-02-2008 07:51 PM
Door adjustment on '32 cares Body - Exterior 0 07-09-2006 10:06 AM
Door Adjustment thiems Body - Exterior 0 04-16-2003 07:27 PM
