This should cover it for you. Click here for the "Basics of Basics" to panel alignment.
Basically, you only move one movement at a time. Other than going straight up or down, where you need to loosen everything, you can move the door all over the place while leaving one bolt tight so the door doesn't move anywhere that you don't want it to. That is the trick, only make one controlled movement at a time. Sometimes it sort of sailing a boat where you "tack" back and forth all the while moving forward? You can do that with the door. Brian |
On the subject of how to pull off putting a painted part on a car without scratching it, the biggest tip is to trial fit the part! This very common sense action is often overlooked for a number of reasons. It is without a doubt the most important step in building a car if you ask me.
Click here for the "Basics of Basics" Trial fitting parts. Brian |
If the tape is going to pull the paint off, then its better to know that now so you can repaint the car before you get too far along.
When I make an adjustment, I open the door and just slightly loosen the bolt and move the door as much as I think it needs then tighten the bolt and close the door and check to see if it is enough. As Brian said you have to be careful that you don't lose all your adjustment and have to start over. |
So much info!
Wow! So much information on here! I never knew the knowledge base even existed. I just spent the last few hours reading so many articles. Thanks once again for all the help. Great site!
Yea, Thats it. That is how I learned to do it as well.
For example if I wanted to move the door forward I would just tighten a bolt on the top hinge and leave the others loose. Then I would lean on the door pushing the bottom hinge forward. I would then tighten one bottom hinge bolt and loosen the top hinge bolt. Now i pull up moving the top hinge forward. After every movement I check to see how the door is lined up. Otherwise, The door is too heavy for me to manhandle. |
| Door alignment problem | 58Apache | Body - Exterior | 4 | 10-06-2007 12:22 AM |
| Door Alignment | SHIFTY101EASY | Body - Exterior | 3 | 05-13-2007 06:35 AM |
| Garage Door Alignment | daveh | Garage - Tools | 6 | 01-02-2007 09:04 PM |
| Door Alignment problems? | 58Apache | Body - Exterior | 7 | 07-20-2005 11:28 PM |
| Door Alignment | Ron M | Body - Exterior | 2 | 08-21-2004 01:43 AM |
