Door Check Pin - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2009, 08:18 AM
Door Check Pin
The previous owner of my 37 Dodge cut off the door check pins so he could take off the doors. The holes in the check bracket are 7/32 and the total length of the pin would be about 7/16. The original pin head a head on it and I was thinking of using a roll pin but I'm afraid that it would eventually fall out with opening and closing of the door. Anyone have a suggestion?
Thanks in advance
Sam
Old 03-08-2009, 09:21 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Not familiar with that xact car but can you post a pix?
If its round stock I sure it would not be hard to fab somthing nice up.
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 03-08-2009, 11:27 AM
Many later model imports used a rolled pin that had a little shoulder so it couldn't fall thru. But depending on the style of car you are building, how about a simple nut and bolt? A nice button head allen and a nylon lock nut would be perfect in most cases.
Old 03-08-2009, 04:45 PM
Joe G's Avatar
Registered user
Maybe use a clevis pin?
(click for link)
Joe G.
Old 03-09-2009, 06:55 PM
Door Check Pin
Thanks for the replies.
Today I went to a large hardware store and was able to purchase something called a screw in post. The only thing I need to is in large the hole of the bracket of the door jam to 1/4in. Rat file here I come .
"Basics of Basics" Rebuilding hinges. MARTINSR Body - Exterior 0 09-30-2007 11:16 AM
test Ball's remote transmitter and receiver GMR Electrical 29 04-08-2007 10:47 PM
assembling float pin / rod Rocket455 Engine 20 04-19-2006 12:24 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 02:15 PM
changing a 4 pin distribture to a 7 pin geno Engine 5 01-19-2004 04:31 PM
