Door clearance with 4 post lift - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2009, 01:59 PM
I'm considering installing a 4 post lift so I can stack cars in my garage. The ceiling is about 12 feet high so I have plenty of clearance. But the door track is at about 8 feet. Does anyone else have this problem? How do you handle it? Can the track be modified to go closer to the ceiling before going horizontal?
Thanks for any suggestions.
Old 05-31-2009, 02:48 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Might contact a garage door service or the door manufacturer.
There are so many possibilities for this.
Some roll up doors go straight up-----not quite enough room for your 12' ceiling, but only the top panel would have to make a transition to horizontal.
Auto garage door opener might present an issue here, but hey, what's another challenge.
I know they have tracks for ceilings right at 7' and those are kinda kool looking (the way they work).
So---a taller ceiling should not be much a problem for the door people to help you figure out.
Old 05-31-2009, 07:30 PM
Wiki Edits: 31
get taller doors...
Old 05-31-2009, 08:44 PM
Yes they make door tracks to take the door higher into the building for more clearance. I considered that when building my shop, but decided to go with roll up doors instead.
A couple of options are available. One is to simply go straight up as far as you want and then do the sweeping 90* turn . You will end up with the same length of track, but some of your door will be vertical. The other option is to stow the door on an angle so you loose some height up next to the door wall, but you get more space as you get further from the opening.
Trees
New 2 post lift by Dannmar. 427HISS Garage - Tools 19 10-23-2011 07:23 PM
Hoist on Lift Post 123pugsy Garage - Tools 2 05-12-2009 08:04 PM
Pro Park 7 Direct 4 post lift CaptainEd Garage - Tools 7 02-01-2007 09:20 AM
4 post lifts Beenaway2long Garage - Tools 11 01-28-2004 07:38 AM
