door clips - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2011, 04:28 PM
door clips
I have 1955 gmc truck and will be using 3 mm pvc foam board for my interior.
Will Au-ve-co 12134 work to hold up the headliner and back of the cab? are just glue up the headliner. I have the small window cab. Is it necessary to double up the door panels? I have read were they use two panels to cover up the clips. I will be using 1/4 closed cell foam.
Thanks
Old 04-02-2011, 11:05 PM
DanTwoLakes's Avatar
Wiki Edits: 22
You don't have to double up the door panels as long as the clips don't telegraph through to the outside. Just don't glue down the foam completely around the clip holes. 12134 clips will work fine, but I would not try to use them overhead, mount a base of 1/4" luan plywood for your headliner, and glue the headliner up with HHR (high heat resistant) top and trim adhesive like DAP or 3-M.
Old 04-03-2011, 06:40 AM
door clips
After I have the 1/4" luan fasten ,should I use luan for the headliner are pvc? Will the pvc board glue to plywood. Thanks Dan for the info.
Thanks Billy
Old 04-03-2011, 08:37 AM
Wiki Edits: 22
Use the luan plywood as a base. Use the PVC foamboard to pad and put in any designs you might want and then glue the foamboard to the plywood base. Here's a link on how to do it: CLICK HERE the tutorial starts at post #18.
Old 04-03-2011, 01:40 PM
door clips
Thanks Dan for the help.
clips Mrwood General Rodding Tech 3 07-18-2007 10:03 AM
door panel clips pop out (au-ve-co 11406) RodFather Interior 3 06-19-2006 01:18 PM
What type of clips do you use for holding door panels on? hemi43 Interior 4 01-05-2006 10:23 PM
Installing door panel clips Mr Bob Interior 20 11-14-2005 03:12 PM
Door panel plastic snaps or clips xk8 Interior 2 03-17-2005 03:09 PM
