Door gap question.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2010, 09:45 AM
Last journal entry: comming along
Door gap question..
Now i have been working on a 37 Ford Tudor for a few years now. Last winter I got the gap fixed in the drivers door. I have a new floor in as well. Now the passengers side is a different case. I have read articles on how to fix the gap, along with help from this site and others. The passengers side door has a even gap at the front of the door. It is kind of wide at the top rear of the door, and almost nothing from about the door handle down. I was thinking.. Is it possiable that I jack up the back of the body to push in the top of the "B" pilar, and pull out the bottom of "B" pilar?? I will keep the front locked down, along with keeping the drivers side locked down.. Thanks.. Al
Old 08-29-2010, 11:00 AM
Here.. i took some pictures of it.. First two pictures of the front, then the pictures of the rear of the door.. Al
ID:	47767   Click image for larger version
ID:	47768   Click image for larger version
ID:	47769   Click image for larger version
ID:	47770   Click image for larger version
Old 08-29-2010, 11:18 AM
Here.. This might help better.. Do you think I could fix this by raising the body at the rear mounting point?? Al
ID:	47772   Click image for larger version
Old 08-29-2010, 05:47 PM
roger1's Avatar
If you just can't get it by monkeying with it. Just grind and weld as necessary. That's pretty fast and easy with a small mig that has good adjustments to it.
Old 08-29-2010, 06:36 PM
shine's Avatar
Last journal entry: some progress
al, give me a call when you can and i'll run you through the adjustment of the early ford body. it's all in shimming.
254 728 3510
Old 08-29-2010, 06:51 PM
Thanks.. Shine.. Will you be around sometime Tuesday afternoon. Can't tomorrow.. Have to go after work and have a A1C done at the Dr.s office.. Al
Old 08-31-2010, 06:08 PM
Thanks Shine.. I calle Shine, and he told me how to fix the 37 door gap. Now it takes me a while to understand things, but he didn't rush it. He explained it quite well, and it seems to be working. I now have a gap of about 1/16", where I had none before. I will try what Shine said again, and see if I can pull it out alittle more.. Thanks again Shine.. You are a good teacher.. Al
Old 08-31-2010, 06:48 PM
shine's Avatar
it's all in the shims. those who say shims shouldn't be used don't know anything about aligning body parts. it is how the factory did it. good luck with it.
Old 08-31-2010, 07:07 PM
roger1's Avatar
Sorry, looks like I gave advice that wasn't so good.
Old 08-31-2010, 08:17 PM
Shine. If i put a 1/4" rubber pad under the cowl, and tighten the bolt down. I then should be able to lower the shims under "A" pilar. I read somewhere that the shims shouldn't be above 3/8". Is that true?? I am hoping that by raising "B" pilar up maybe 1/8" more.. I would then only need to maybe go up on the "A" pilar by 1/2".. Should I then put any filler pieces in between the areas that are raised up?? Al
Old 09-02-2010, 06:01 PM
Well I did what Shine told me. I do have a gap now, BUT!!! Now here is what I have. I still have the good gap in the front. Good gap on top. Good gap from the corner down to the reveal line. I also have a fairly good gap at the bottom.. I have about a 1/16" gap in the center.. Now what?? I did pull on the door handle alittle, and I end up with a good gap from the top to the bottom.
I was thinking.. If I got the old 2x4 out again, and supported it against the garage wall. Now if I put the other end against that door post. Do you think I could move it over a little with the 3lb sledge??, or is that a bad idea.. Al
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Fuel System question Ratoflic Engine 6 01-23-2010 12:10 PM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
