Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Door handle spring
Old 01-13-2003, 11:30 AM
pasadenahotrod pasadenahotrod is offline
Post
In the triangle with the link that mounts to the door is a square shaft to which the inside door handle mounts. On the back side of the triangle is the actuator plate which attaches to the link which goes rearward to the latch assembly at the edge of the door. The actuator plate pivots in a housing which has 4 bent ears retaining it to the plate. In the side of this housing are two slots (one on each side). You will notice that the actuator plate has a "roller coaster" with two vallies, one small, one larger. The straight end of the spring with dogleg in it goes through the slot on the side of the plate housing from the inside. Now, here's the catch. Hopefully you have your latch with spring on the other side. This will tell you which way is opposite from the spring you are installing. Install yours correctly and "BINGO" no more sagging outside handle. This true for all Fords from 32-up and some earlier (mostly 30-31 Fordors).
I love technology.
