Door handles replace 29 ford 2 door - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2007, 11:08 PM
Trying to figure out how get the handle assembly out. Seems like there is a clip locking it in place. Hard to see or access.
Old 06-08-2007, 11:23 AM
Not A T 25's Avatar
Takes Guts To Cut One Up
Inside or outside handle?
Success is getting what you want but happyness is liking what you get.
Old 06-08-2007, 11:33 AM
29 handle
Thanks for reply. Iam replacing outside handle. However I got it out, It was just stuck. In looking inside of the door, one could see a bunch of strange stuff all of which one wrong move and you'll have the bottom of the door full of springs, clips and parts.
Thanks for reply, I got it handled.
SV
Old 06-08-2007, 02:50 PM
The Model A outside handles have a square shaft with a section machined square with opposite corners near the end. The handle must be pulled out, then rotated 45 degrees so the corners line up, then pulled and back again. Kind of pull-twist-pull-twist-pull. Reverse applies to installation.
It was an early theft prevention idea since the passenger side locking handles just lock themselves rather than the latch assembly. The driver's side doors lock from within.
Old 06-08-2007, 04:07 PM
door handles 29
That is fantastic, you are worth your weight in gold, thanks a ton. The supplier I bought them from did NOT know that! I have had 3 Model A's in 45 years, you would think I would have learned that trick.
Tks,
SV
Why only one door lock on a Ford F-100? Z-Money Pit Hotrodding Basics 38 12-30-2011 05:44 PM
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Ford door latches CaptnSkull Body - Exterior 2 01-15-2003 07:22 PM
